1 - 2 of 2 Posts
Hey Guys. I have an issue with my turn signal on my 03 1300R. Left turn signal is working great. However when i turn the right turn signal on the the front running light just goes out instead of flashing and the rear just stays lit. Also my indicator light on the instrument cluster doesn’t come on. Ive checked the fuses and they’re fine. Im assuming the relay is good since the left signal is having no problem. I tested the bulbs and they all seem good. Any help you guys can provide would be appreciated. Im stumped at this point.
Clean and lube the TS switch.
Old grease is preventing a good connection.
Happens frequently in cold weather.
When you turn Rt TS on, the running light goes OUT, Rt TS filament should flash.
Open the clam shell, unscrew the screw that holds the lever in place.
Another screw on the hold-down plate and pull it out.
1 - 2 of 2 Posts
