Hello fellows. I have a little issue. Had some charging problems and strip my bike ( the left side) because all the test and measurements had send me to the alternator stator whitch was in very bad condition. Also the flywheel was damaged ( see pics) . I was amazed when I found a little bolt pin . My question is: where it came from because I 'm afraid that after I will replace all the broken parts not to happen again. As far as I know, there are only two pin bearing in the motor: the one that the flywheel stays on ( but that one is to little for this pin and it was ok, no pin bolt missing ), and the one from the clutch, but that is too big for the pin bolt I found and also the clutch was running nice and smooth, no problems there .
I have also check all the diagrams from here: https://www.mrcycles.com/oemparts/l/hon/5053eed8f870021c54be5533/2003-vtx1800c-a-parts but I have not been able to identify where it might be.
By the way, I have a 2002 1800 VTX C
Any suggestion ?
Please be free to write any ideea where it might be from. Pics will also help a lot.
Many thanks.
Any suggestion ?
Many thanks.
