1 - 20 of 21 Posts
:D I am not happy with the Cobra Classic Deluxe Slash Cut exhaust that I currently have on my 2004 VTX 1800n. I am looking at the V&H'S and the Jardine Drags. I was told that the Jardines will out perform the V&H's. Any input would be appreciated.
Yes, the Jars do a little better than the V&H. 8)
Welcome to the board!
I have the Jardine's on my retro and they are great. I went riding with a bunch of Harley guys this weekend and they said my bike sounded great, loud but great.
:D Thanks guys for your response. I think I will try the Jardines to be a little different.
VTX 1800N spec 2, power commander, thunder teardrop airkit, kuryakyn iso grips, kuryakyn switchhouse covers, kuryakyn motormount accents, cobra driveshaft cover, showchrome swingarm covers, showchrome side covers, cobra classic deluxe slashcut exhaust.
vance & hines vs jardine
Back in August I was looking for the Vance & Hines to put on my new 1800c. They were back ordered until the middle of November. Since I disliked the standard pipe so badly, I began to look for a replacement. I purchased the Jardine Slash Cuts. My impression:
Nice sound
Loud enough to occasionally set off a car alarm
Not too loud to be obnoxious
Look great
They have the crossover, no additional tuning up needed
The only drawback I have found is this - I called the factory which is here in California and asked them if the baffles can be removed and they can be. The problem is getting them back in easily. They are apparently wrapped in fiberglass or something like that and the re-install is difficult to next to impossible or so I have been told.
Not a major problem, otherwise I like the looks and sound of the Jardine. The quality of the chrome is very good except for the stupid clamps that you use for attaching the heat shield. They can be hidden though. I would purchase again.
Alright, here's mine. Go with Jardines. Here's my opinion...
http://netjam.com/html/vtx1800-Jardines.htm
Cheers!
Netjammer-
jardine
I love these pipes..slashcut look great ,sound great......hdl great price(thanks hal)with builders discount.....dynoed real strong....build away guys
I'm a bit partial to the bigshots, but I'd like to hear the jardines though. The bigshots sound really awesome with the thunder monster baffles!
Rob
Correct me if I'm wrong, I thought that with the 2 to 1 exhausts you got better performance. Now the Jars come with a 2 to 2 set up, and the V&H's has a crossover that makes them a 2 to 1.
So Chicago-Spike, . . . how is it that the Jars are a little better than the V&H? I'm just curious?
Oddly enough, I was perusing an August, 2003 copy of Motorcycle Cruiser this morning. In it, they run a comparo of seven aftermarket pipe systems. (Bub Chambermaids/Hard-Krome American Classic Straights/Jardine Straight-Cut Drags/Muzzy Classic Megaphone/Roadhouse/Shogun Slashers/Supertrapp Mean Mothers).
The Shogun and Supertrapp set-ups were best left in a dumpster, while the Jardines provided good response at low rpm, only to fall way off in torque and power delivery at anything above 4,000rpm. (These runs were done with a Cobra Fi2000 unit installed in the bikes. The Cobra set-up can be adjusted to richen the fuel/air mixture, but unlike the Power Commander unit, cannot lean out the mixture anywhere along the fuel curve. Some aftermarket pipes will "cause your mixture to swing radically from too lean to too rich".
If you are looking to simply change the sound of your ride, just about anything will do. If you actually want performance above that delivered by your stock exhaust set-up, I personally would bite the bullet and go with the V&H set-up. And I would install a fuel management system to aid in tuning them in for the best performance possible. JMHO....
retro
I'd like to know as well as I'm currently looking to change pipes. What have been some of the better performing aftermarket pipes for the retro?
1 - 20 of 21 Posts
