1 - 9 of 9 Posts
No its not some new sex toy.... :shock:
Since my bike was bumped in a parking lot, I have become obscenely paranoid about noises etc.......The upper left fork cover is loose and vibrating at the top.....
I recently did my steering bearings and I assume this issue is from that.....
There is a gap at the top of each fork cover....I have always had a gap at thetop of the left one, but it is now vibrating...
Any thoughts on a fix????
Thanks folks....
Discussion Starter · #2 ·
:bump:
Anyone??
Buehler? .......... Buehler?................Buehler?............
Maybe a pic of the area should give people an idea of what might be the issue. Good Luck.
I will get a pic up....
But basically it is the very top of the frok cover, where it meets the top fork bridge......
Thecover itself is vibrating and making noise.....and there is a gap between the cover and the bridge......
there is a pinch bolt there, see if it is loose and look for the torque values to tighten it up. Not a big gear head so, thats all I can contribute to the matter.
Thanks....Checked that....fork is not loose...just the cover......I was thinking I could add some stainless steel washers under the moutning tabs to raise it up, close the gap and hopefully silence the vibration......I dont know why there is a gap now to begin with though....
I first noticed a gap way back when I installed my front springs.....there wasnt a gap, then I loosened the top pinch bolts (cant remember why) and the gap opened up....now that I have had the top bridge off and back on there is a gap on both sides.... :? :? :?
Like I told you before I am not a gear head and now you see that I dont know what I'm saying but, I know that duck tape does wonders!!!
:lol: Good Luck!!!
Hi,
I installed Retro fork covers on my C at the same time as I did my steering head bearings. I didn't have a vibration like you do but I did have the gap at the top of the covers that you speak of.
I did what you mention and put washers under the mounting tab to raise the top cover and close the gap.
I don't know if that will fix your vibration, but I do know it will fix the gap.
Hope that is some help.
Cheers,
Mike
....after the above recommendation, then you do the duck tape mod!!!... :wink:
1 - 9 of 9 Posts
