Stealer installed National Cycle light bar....now I'm getting a vibrational buzz at several different RPMs.......it's annoying. Suggestions on how to make it stop?
From the speedo? If so do a search for speedo buzz.
Speedometer Vibration
Take some Velcro (soft side) and cut in 1" lengths Then fold each in half and cut a small V notch in center (a punch will not work) and peel the back off and place one on top of each mounting studs.
The sticky side keeps them in place if you ever need to remove the housing in the future. If you use rubber O rings, they tend to fall off and flatten out.
I too have a vibratinal buzz at certain rpm's. I can't tell where the heck it's coming from. Doesn't seem to be the speedo, I've pressed down on it in various spots and it doesn't stop. Headlight? Maybe. Should a person just go ahead and do the anti-vibration fixes or is there a sure way to locate this noise?
It's not the speedo......it only started after they installed the light bar.
