1 - 20 of 22 Posts
VSS and oil change; rear tire
Replaced Vehicle Speed Sensor and new oil & filter @ 57,761 in Custer, SD.
Back home on 8/8 put more than 11,000 miles on the bike in 2 months with 2,000 of that in the Black Hills around Sturgis
Discussion Starter #2
Replaced rear tire @ 62,581 with Kumho Ecsta 195/60R-16...old tire, Hankook Ventus 185/55R-16 was bald after 32,000 miles; oil and filter change using Bosch 3300 and Rotella T6 full synthetic. Also secured LeatherLyke brackets a little better and replaced rubber grommets in bags.
Replaced fluid in clutch reservoir at 63,182 miles. Brake fluid is clear
Discussion Starter #4
Replaced front tire @ 67733 miles; old and new are Shinko 230 Tour Master...I got 22,688 out of first Shinko.
67741 miles, checked valves, replaced plugs
Discussion Starter #6 (Edited)
71,290 replace rear drive oil, lube rear tire and gearbox splines, checked valves (all good again), lube shifter spline, removed fairing for some cleaning and minor repairs, changed oil and filter (Bosch 3300 and Rotella T6), checked brake pads (ok)
Discussion Starter #7 (Edited)
Replaced clutch with Cycle House pads, MTC springs, Barnett steels; changed oil & filter; added Spike air intake to replace stock intake. 75,334
Reactions: frnkcat
Discussion Starter #8
Replaced plugs with brand new @ 75,468
Discussion Starter #9
Mileage at beginning of 2017 is 77,748...only 10,000 miles in 2016, I need to do better this year!!
Discussion Starter #10
Replaced rear brake pads at 78,399. Front pads good.
Discussion Starter #11 (Edited)
Beachbum's N
Replaced rear car tire @ 80,985. New tire is General G Max 195/55-16, old tire was Kumho 195/60-16, worn in the center which means over inflation, but I never ran more than 40 lbs in the tire. No more Kumho, just over 18,000 miles.
Dan
Discussion Starter #12
New battery @ 81,395
Discussion Starter #13
Changed oil & filter, rear gear oil, front brake pads, lube shifter pivot @ 83,731.
Discussion Starter #14
Changed oil and filter, 87711
Discussion Starter #15
New front tire @ 88,719. Another Shinko 230 Tour Master...got 21,000 out of the old one.
Discussion Starter #16
91,400 miles...valve check, replace coolant with Engine Ice, lube rear splines, clean starter button, replace clutch and brake fluids, replace rear gear oil, new front brake pads, lube shifter spline, change oil and filter and an overall much needed cleaning.
Dan
Discussion Starter #17
New fork seals @ 93,773 miles
Reactions: StarrRider
Discussion Starter #19
You're tough on front pads, huh?
I think it's time for me to get new ones. I think I've got about 20K on them.
LOL, back in June I tried a set of cheapo pads on the front and they did not last at all. I went back to oem pads before my trip to Texas in April.
Dan
Discussion Starter #20
Oil change 96,532
1 - 20 of 22 Posts
