1 - 13 of 13 Posts
I’m 200 pounds and wife is 160. Just started to go 2up with her. Bike seems underpowered with us both on. Should a 1300 feel that much different with 360 vs 200? While leaning it almost feels like there is a lot more resistance on the tires. Hard to explain. Almost a rubbing sensation. Tires are Michelin. Tire pressure is 26 front and rear. I don’t know how to read the suspension. Attached picture. What should I set suspension to and how to so do it? Thank you
1-5 ....shock wrench or strap wrench....I would start at 3....twist in Numerical order ....I cant be more help ..I ride solo and have 1800 shocks....Goodluck
Its said u cant go all the way around...I did by accident ..zero problems..
Thanks TennX. I do have the tool from previous owner. I can’t tell what it’s set to now.
I answered you over on the Cafe. Great guys on both sites.
Reactions: TennX
I would also bump you're tire pressure up to 36 front 40 rear
Discussion Starter #7
I can always count on you guys. Thank you. I can’t even budge the shock with the tool. Any tricks? Would putting bike on a lift help?
It does help to take the weight off...they look a little funky...maybe a squirt of wd 1000 ...lol..i mean 40...good luck
while your at it ...see what shape your shock bushings are in...
You got the post on tire pressure?
just checkin'
Tricks? looks like it's on 5
Tennx is right, a good dose of WD40 or pick up some of this at your local auto parts store - https://www.amazon.com/Seafoam-Extreme-Marine-Rv-Lubricant/dp/B0002KL6TM/ref=sr_1_2?crid=9IQ89C4UNUAP&dchild=1&keywords=seafoam+penetrating+oil&qid=1596540604&sprefix=Seafoam+pen,aps,175&sr=8-2
Stuff works GREAT!
When riding by myself, I keep my shocks set on 3, with my wife on the back, I bump them up to 4. That's all you should really need. I agree with others, I think your running your tire pressure a bit low. Low tire pressure will make your bike handle and do all kinda of weird things in cornners, especially riding 2-up.
Keep in touch and let us know how things are going... safe riding.
Having the bike on a lift or stand def. makes changing the rubber shock bushings easier. Do one side at a time. The other side will hold it in position with minimal movement. One bolt is longer than the other.
Discussion Starter #13
Tire pressure adjusted and I was able to swear at the springs and they finally moved. Jacking bike up did the trick. Thanks all. Now time to ride!!
1 - 13 of 13 Posts
