Rebuilt fuel pump. Has same 50psi as original, with new fuel sock. Tested and working.
What do you mean for placement, Prankster? Thiscame from a 2007 1800 which had an external pump. They are mounted under the battery box, almost directly below the swing arm pivot. Did I answer your question?Brett, where is that for placement.
Just asking for a friend.
And, I wonder, if this used as a replacement for a currently in tank pump, where would one put it?
Happy Sunday!
Yep, just trying to think. If I have to pull mine. 02, R last ime I started her she acted odd. pluse 21 years old.. Would it be possible to replace with this and where it would mount. Plus I'd get just a tad more fuel in tank.What do you mean for placement, Prankster? Thiscame from a 2007 1800 which had an external pump. They are mounted under the battery box, almost directly below the swing arm pivot. Did I answer your question?
I think I have seen that kit before. As for your bike, I'm not sure how you would mount it; the external pumps have a bracket with threads as well as mounting with threads for the bracket on the bike. There are YouTube vids out there that take a good look at it.Yep, just trying to think. If I have to pull mine. 02, R last ime I started her she acted odd. pluse 21 years old.. Would it be possible to replace with this and where it would mount. Plus I'd get just a tad more fuel in tank.
Did find this?
QFS OEM Replacement EFI Fuel Pump for Honda VTX1800 2002-2009, Replaces 16700-MCV-R13
FREE 2-DAY SHIPPING, EASY INSTALL from the AUTHORITY on OEM replacement Fuel Pumps. SAVE up to 70% off on parts for your Honda VTX1800 02-09 with HFP-382-Ywww.highflowfuel.com
Did find this?
I suppose you're right. Should be able to strap it in place under the battery box. Everywhere else is a tight fit!One thing for sure, make it easier to add aux tank. I am sure it can be done.
