1 - 12 of 12 Posts
Driving home one night Speedometer quit and FI light came on back firing when I let of the throttle and cutting out! Does anyone know what might cause this tried some quick fixes but nothing seems to fix the problem checked charging system fuses battery connection and all that was good! Please HELP!!!
Did that and cleaned positive and negative on battery. Couldn't find where it's grounded to motor or frame.
Look up the instructions on here for the ground fix. It shows where the grounding connections are. It's a must-do.
Like the guys mentioned already, Honda dropped the ball on the VTX. I feel like it was a manufacturing oversight and not the engineering but they didn't prepare the grounds. Exactly how your grounds are set up depends on which model and year it is. This was a problem which affected just about every VTX so there's lots of information on the net as the bikes age and the grounds build up a little corrosion. It can show itself in about a dozen different ways and lots of different symptoms. There are a handful of grounds on the bike and you should address each one.
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX.
Click the “Advanced Search” button
Now, click "Search Single Content Type" and add you keyword to search
A few VSS have failed.
Mainly the older models>>CORRECTION:: 2006 and 2008 on the threads below.
Some went into "limp home mode".
Check(pull) FI error code.
VSS(vehicle speed sensor) outputs +5v pulses while the rear wheel is turning.
68 - 72 pulses per revolution per my counting.
Somewhere around 50k to 52k pulses per mile.
Google: "vtxoa: vss"
I see threads..
http://www.vtxoa.com/forums/showthread.php?440210.html
http://www.vtxoa.com/forums/showthread.php?350354.html
http://www.vtxoa.com/forums/showthread.php?336801.html
More info may be helpful...I'm not sure what all going on...if you let off the throttle the bike dies ??? I had an issue recently...While doing about 70 mph the FI light came on and the bike died on me...Came to a stop and put the bike in neutral...it started up fine...put it in first it rolled a few feet and died again...The kickstand switch was sending the ECU a signal that the kickstand was down...Shutting down the engine...even though it wasn't down...there are two safety switches that can send the ECU an error message and shut your engine down...Clutch and kickstand switches...More detail about whats going on might help...?
1 - 12 of 12 Posts
