2007 VTX 1800F lose power when hot, Please Help!
Hi, I purchased a 2007 VTX 1800F Spec 3 a month ago. It only has 4K miles. I love the bike but I have run into an issue I can not figure out:
Shortly after the bike gets hot from riding, the bike lose power above 3000 RPM's on all gears. At 3000 RPM's in neutral, give the bike some throttle and the bike seems to choke to idle RPM range but experiences a horrible idle: sputtering, popping, jumping...... Release the throttle and the bike idles clean and throttle clean up to 3000 RPM's.
If I allow the bike to cool for a little, this behavior stops for a short period until the bike heats up again.
I have tried to recreate this behavior by letting the bike heat up in from cold to start in idle but it only happens when the bike heats up under power.
Other things I have noticed: The bike reeks with the smell of gas after it runs.
I cant get the bike to stall and I haven't been able to get any error codes from the bike. This model doesn't carry oxygen sensors or a fuel pressure regulator.
I initially thought the fuel pump may be failing but I would like to be sure about that before I spend $400 on an OEM pump for this bike. I haven't performed a fuel pressure check because this behavior doesn't just happen on the bench.
Has anyone had this problem or know what it may be?
