1 - 15 of 15 Posts
It will fire plugs if you are out of gas.
ECM has no idea if fuel system is pressurized.
What happened since the previous problem???
Changed out bank angle sensor, Rechecked all wiring, changed out the sensor on battery box, did not have the speed sensor on back of engine. Did not change that. All indicator lights on tank cover come on. Looks like the only thing left is speed sensor or something in wiring harness
Check for continuity on the crankshaft sensor wires. About 193 ohms resistance. 10 volts AC peak to peak.
Discussion Starter · #12 ·
Well here is what I have come up with so far. Finally found manual and there was no batt voltage on coils. Did some troubleshooting and found that if I unplug speed sensor I get batt volt.. I can't follow the prints since my eyes bother me. Trying to look up where to go to next
Lunch or nesting material for critters? Wouldn't be the first time the lil bastages chewed up a wire where you can't see it.
Reactions: Merry Prankster
1 - 15 of 15 Posts
