In the USA they all had the same HP and torque ratings between the models. The only difference was where the info was from. Honda states the HP for the 1800 as 102. This was just the engine on a bench dyno with no drivetrain attached. The real world, at the rear wheel HP rating is around 87ft/lbs with the losses from the drivetrain and gears
Your first 5 posts must be seen and approved by a site moderator before they will show up on the public board for all to see. This helps us keep spam off the board. Please only post once and allow time for your post to be seen thanks ;)
It turns out that wikipedia provides other technical data.
Winter is coming, but if it gets warmer, I will go to the dynamometer and measure the power of my VTX 1800, personally I only measured the speed and it came out about 130 miles, which is a bit more than Wikipedia says. Thanks and best regards.
Or you can direct all your questions to ERVIN. The Living god. HE knows it all.
:grin2: Don't be pissed! Educate yourself instead! >:)
There are many members here, you can learn from like Spike, Hans, Enduro, Harkon, Chuck, Monty...
