Burnouts, riding long term with a slipping clutch
Sent from my SM-G965U using Tapatalk
Must be riding with the slipping clutch. Never did a burnoutBurnouts, riding long term with a slipping clutch
Who's clutch friction plates are you using? Did you soak them in motor oil overnight? The steels too? MTC friction plates are notorious for sticking especially when new. The bike will jump forward but usually releases right away. Did you try bleeding the clutch line yet? Start there. If you assembled the clutch pack dry then you have to backtrack.Problem is, when I shift into first, the bike automatically starts moving. The clutch is fully squeezed and the bike still moves forward! Any ideas gentlemen?
They're MTC. I soaked them for actually 2 days. I bled the clutch line beforehand and changed the clutch fluid. Maybe I need to bleed it again. Air bubbles possibly in the line?Who's clutch friction plates are you using? Did you soak them in motor oil overnight? The steels too? MTC friction plates are notorious for sticking especially when new. The bike will jump forward but usually releases right away. Did you try bleeding the clutch line yet? Start there. If you assembled the clutch pack dry then you have to backtrack.
I checked the slave piston, rod and bearings before changing the plates. Cleaned and lubricated them...You should have checked the pressure plate travel before bolting the cover in place.
Clutch slave piston, rod, bearing in the pressure plate..
A failure somewhere.
Oh Damm. Didn't even think of that 🙄Pressure plate travel to release the clamping pressure on the clutch pack.
Not sure if you all are still on here... a lot of older posts. I would be interested in any troubleshooting tips. I am having the exact same issue. Just bought it. Bled brakes and clutch. Replaced clutch steels and friction plates for good measure. Still when it gets hot it starts slipping and then ends up getting to a point where I can't get it moving when releasing the clutch handle. If I let it totally cool down it goes back to normal.The neutral light comes on and I assume goes off when you activate the shift lever? Do you feel any resistance from the gearbox when upshifting or downshifting? There are no synchros in this box so it's usually clunky. Most importantly are you getting any movement of the speedo when in gear with engine running and letting out the clutch? With the bike "in gear", engine off, does the bike roll easily? My questions are meant to target the chain of components that gives your bike forward motion.
Rebuild the clutch master cylinder. It's possible the return port is getting plugged by debris still in the line possibly from the seal. Not expensive and easy to do.Not sure if you all are still on here... a lot of older posts. I would be interested in any troubleshooting tips. I am having the exact same issue. Just bought it. Bled brakes and clutch. Replaced clutch steels and friction plates for good measure. Still when it gets hot it starts slipping and then ends up getting to a point where I can't get it moving when releasing the clutch handle. If I let it totally cool down it goes back to normal.
