Partzilla WATER PUMP ASSY. 19200-MCH-000 by Honda $246.15 26% OFF $183.37
Honda parts house WATER PUMP ASSY. 19200-MCH-000 $189.54
It does not look like DLP is a vendor any longer.
Hondadirectline 19200-MCH-000 WATER PUMP ASSY. $209.23
Partzilla is where I have been shopping for the past 9 years
Bookmark the URL for your year and model.
Google gives more choices.
Honda parts nation WATER PUMP ASSY. 19200-MCH-000 Your Price: $172.30
You can always try to negotiate at a local dealer.
Shipping cost vs tax.....
Thank you for your reply,don't know what the forum would do if you weren't here to help.
Discussion Starter #4
The water pump isn't leaking at the weep hole,it look like an oring might be bad.but with 65000 on the bike might be better to change pump out.didn't know it was going to cost so much for water pump
1800 seems to be hard on water pumps and Vehicle Speed Sensors.
A friend has a Suzuki Burgman and he could buy the seal and bearings individually from the parts list.
My water pump has 193k miles on it.
Be sure and order the 2 rubber seals that seal the coolant tubes to the pump. They don't come with the pump.
Discussion Starter #8
Thanks for every ones help,going to replace the water pump cover O ring see if that is the problem.I order the O rings from partzilla.thanks again
