dittodanX said:Amsoil--oil and final drive fluid.
Me too.NEBTIGER said:Mobile 1 Red cap - never had a problem with it.
Honda Oil for the final drive
Just keep in mind that the manual specifically states not to use oils with friction modifers in them. And if you do and your clutch starts slipping, the only way to repair the damage is to replace the clutch plates. Just a word of caution that's all. 8)Heavy said:I use Castrol Syntec in the engine/tranny. I'm moving to Conklin (synthetic) in the differential the next change. I will probably try out the Conklin oil in the engine sometime soon to clarify or hopefully dismiss the "moly' debate...
