81 - 100 of 107 Posts
Not sure if this was mentioned but, what about "Ethanol Free " ?? Can leave it in as well all winter from what I've heard and burns much cleaner overall.. No Additives . ....
Discussion Starter · #83 ·
true straight gasoline will weather storage better than ethanol but I'd still add a stabilizer to it for storage over a month or more. The part about straight gas being cleaner is not true. Ethanol is a cleaning solvent thus cleaning your fuel system and burning cleaner,hence the reason the tree huggers want more ethano' added
But when gas / ethanol goes to 15% it would be better to run ethanol free?
It is always better to run ethanol free. !0% won't usually hurt anything unless stored unstabilized but 15% looks like a no no.
Discussion Starter · #87 ·
Yes, and do NOT worry about e15. Our e15 fuel is a long time, read decades, away from being the ONLY fuel available. These newbie e10 users are like Chicken LIttle running around claiming e15 will be here next week and that's all we will be able to buy. No, it won't. It took e10 30 years to get to them, we have had e10 here since the early 1980's. e15 still isn't readily seen here, so it will be a while :thumbup:
PS...we haven't had the choice of straight gasoline or e10 here in 20 years. e10 only in all stations in all grades and our engines run just fine
My VTX likes mid grade ethanol free!
Vehicle Motorcycle Motor vehicle Sky Automotive tire
I like to run a mid grade ethanol free gas in my bike,It keeps it running smooth and strong.I posted a thread on how I deal with ethanol issues if you want to check it out under LowNLean, the thread was Ethanol treatment? I know a lot of people say there is no issue with ethanol fuels, everyone has their own opinion,My bike does much better on ethanol free gas, a lot of the people who think ethanol fuel is the same have not had access to non ethanol fuel for a while.People should use what works best for them.If you have the availability try a couple of tanks of each and see what your bike performs best on.
Discussion Starter · #89 ·
Yep, every year when I ride the great roads of this continent I put whatever gas is out there in my bikes. I can't tell a difference in how they RUN. MPG-wise sure you can tell when you're running straight gasoline as you get better mileage out of it. The GRADE/OCTANE has absolutely ZERO to do with how good the engine performs. If you say yours does better with mid grade, I say run a bottle of Techron Fuel System cleaner through the bike, it is the ONLY recommended cleaner by Honda and most other vehicle makers. Split the bottle over 3 tank fill ups and use the low octane. Read the first post about how octane works in an engine, or Google that question if you don;t believe the members here. Your VTX was designed to run on the lowest available octane. The only thing using mid or premium will do is make the oil companies richer 8)
Very interesting reading
Funny thing is I was always told to use the higher octane because there is no ethanol in it? But from reading here I have been wasting my hard earned money putting the expensive stuff in the VTX.
Thanks guys
well i can now officially say that running 87 vs 91 i have picked up about 6.5-7mpg. And the bike feels way better on hard accel.
Thanks!
Great, thanks for responding. I have read that some gas that was tested as high as 37% ethanol which was supposed to have up to 10%.:shock:
Discussion Starter · #95 ·
Your car or any vehicle that was not a Flex Fuel would not run right if it had more that e15 which with your number would be e 37 or 37% ethanol. Timing needs to be different and the ECU has to change to recognise that ethanol level.
Awesome post i never thought of that i have always ran premium in my bikes until now.My only problem is my small engine teacher would flip over u calling it a motor, it is an engine it doesn't plug in.
Generally I've seen these test numbers because of damage done to the engine and then test what is in the tank so yes it does happen but I think it is rare.
What octane Gas should I use?
How to “Get Gas” without leaving skidmarks
by: Brian "Tapper" Davis
One of the most frequently misunderstood issues among the VTX community, and indeed among all folks concerned with performance and appropriate care and feeding of their motors is the subject of gasoline, and more specifically the mysterious octane number. Oil companies have gone a long way to foster this mystery, by marketing gasoline with higher octane numbers as “premium”, and inferring that the golden road to more performance, cleaner widgets, and hot chicks, is to spend the extra dough on the higher-octane stuff. Well, sorry to be the one to break this to you, but you’ve been had. So lets take a quick look at octane, and then get to the big point – what should you run in your VTX?
Now the truth is, octane is actually a chemical, which comprises an important part of the chemical soup that is gasoline. But here’s the thing – octane the chemical has absolutely nothing to do, with “octane” the pump measurement. So what is it?
In a nutshell, the octane rating of a fuel is a measure of its ability to resist detonation, ping, pre-ignition, or knock. The number we most often associate with octane is the "Anti-Knock Index", or the "Pump Octane" number. This rating is an average of two different measurements - the Motor Octane Number, and the Research Octane Number. Both of these measurements are taken using a special single cylinder test engine that has a variable compression ratio. The RON measures the knock resistance of a fuel during low RPM, light load conditions, while the MON is representative of high-speed, high load operation. As a result the MON will always be lower than the RON, but for our purposes the Research Octane Number is more significant because it more closely represents the way a low rpm V-twin motor is operated. So “Octane”, has absolutely nothing to do with the energy content or quality of gasoline. It’s just a measurement of when the gas will make a motor of a specific configuration begin to knock.
Lets take a moment here to define a couple of things important to understanding this discussion.
Knocking (also called pinking or pinging) in internal combustion engines occurs when fuel in the cylinder is ignited by the firing of the spark plug but burns too quickly, combusting completely before the optimum moment during the compression phase of the four-stroke cycle. The resulting shockwave collides with the rising piston, creating a characteristic metallic "pinging" sound. The fuel is normally ignited slightly before the point of maximum compression (the spark advance) to allow a small time for the flame front of the burning fuel to expand throughout the mixture, so that maximum pressure occurs at the point of maximum compression. It is only when this flame front arrives too early, for whatever reason, that the knocking effect occurs. If allowed to persist, knocking can cause vibration and damage to engine parts.
Knocking is a different phenomenon from pre-ignition, which occurs when the air-fuel mixture in the cylinder ignites before the spark plug fires. Pre-ignition is caused by heat buildup in engine components or overheating of the air-fuel mixture during compression, and cannot be prevented by delaying spark plug firing. As such, if pre-ignition is allowed to continue for any length of time, severe engine damage can result. Pre-ignition is bad bad stuff, and changing the octane of the gas won’t affect it.
Generally speaking, a higher-octane gasoline prevents knocking by either slowing the burn rate of the gas, or by increasing the difficulty of lighting it up. The idea here is to prevent the gas from burning too fast, and causing knocking. So the octane number has no bearing on the quality of the gas. But it does have a bearing, on how well your motor can utilize the gas and extract the maximum energy from it. However, getting too far into details of this would require a pretty damn big article, so I’m going to generalize a bit, for the sake of brevity here.
First, consider that gas burns faster under pressure. The more pressure, the faster it burns. Therefore, a high compression motor will burn gas faster than a low compression motor. The VTX is a relatively low compression motor folks. So, we don’t really want a slow burning gas.
Second, the burn timing in your motor is hugely important when considering how well the motor can develop power from a given amount of gas, and this timing is determined by the ECU, which can manipulate the spark advance of your engine. Normally, the timing in your VTX is pretty close to 8 degrees before top dead center, but the ECU can and does retard or advance the spark timing to respond to certain running conditions of the motor, like coolant temperature, rate of increase of Rpm’s, or any of a number of other conditions. But none of these parameters are accessible (yet) by you, the itinerant tuner. So, you have no way to manipulate the spark to match the burn speed of your gas. Since the VTX is designed by the factory to use 87 octane gas, if you run something different, the only possible way you have to tune your motor to use a different octane, is to manipulate the compression ratio of your pistons.
So here’s the thing: Unless you have changed the pistons in your VTX, a higher octane gas will have the effect of de-tuning the motor, and therefore reduce its performance. Now, the amount will probably be minimal, but it’s there. That’s the meat and potatoes guys, but there are a few more things we can infer. First, at higher altitude your compression will be slightly lower, and therefore you can get away with running a slightly lower octane gas. In fact, in areas like Denver, where the altitude is up around 5,000 feet, you’ll find gas stations selling 85 octane gas. But you’ll never find a gas station in Texas selling 85 octane. Since the altitude is much lower, the octane rating needs to be a little higher, so regular gas is typically 87 octane.
Second, gasoline quality is dependant on a lot of things, but octane isn’t one of them. In fact, there is almost no real difference in “premium gas” other than the octane number. Federal law dictates the amount and type of most of the additives in gas. So by definition, they’re all pretty similar in nature.
Except.
Gasoline is formulated according to climate in the US, and gasoline refiners use 6 basic formulations based on the expected temperature in the area they are expected to be sold in. Gas companies vary this by season, and by location (it also tends to be colder in Denver than in Dallas). So that gas you bought in Dallas might not give you great performance in Denver.
These days, unleaded oxygenated gas is far superior in performance and energy characteristics as compared to the old leaded gas of yesteryear. We generally have very good gasoline available to us at the pump.
Lastly, just remember this simple rule of thumb: You should always use the octane rating recommended by the manufacturer for your motor. But, if you are riding in a climate significantly different than sea-level at 80 degrees Fahrenheit, then use the lowest octane gas you can find that will not cause your motor to knock.
One more thing – many cars these days have anti-knock sensors built into them (the VTX doesn’t), and those sensors are used by the ECU to manipulate the spark timing. So, if you run an octane significantly different from the manufacturers recommended octane number, the ECU will detune the motor in real time, and you won’t get any knocking – but you absolutely will lose performance. Use the recommended gas. If you’ve been running a higher octane gas, and spending the dough to do it, then I hope this little article will save you some bucks, and in the process gain you some performance. Good luck!
Last update: 2005-06-22 15:43
Author: Tapper
I am new to this site and bought my first VTX this year. I have always been of the "old school" that the higher the octane, the better the performance on a motorcycle. Thanks for posting this article and opening my eyes. Can't argue with the facts. I've been running 91 & 93 in my bike since I bought it. The next tank of gas will be 87 for sure. Plus, based on one of the other threads, I'm going to synthetic oil as well. I really appreciate you folks taking the time to share this knowledge with us 'unfortunates'..... Darrell
I may be waaaay wrong but I swear there's a factory sticker on my bike that says something about running 91. Idc what the sticker says if u guys run reg gas and get better mileage and it's better for the bike, then that's what I'm running from now on!
