I have a Honda OEM polycarb. If taped up with masking tape pretty good, do they crack easily when sawn with a fine metal blade in an electric saw? Who has done it? How did you do it? My shield is about 3" too high.
I have cut many windshields, You MUST cut the windshield WET, if you are using a jig saw use a squirt bottle (another person helps) and keep the cut wet. if you do not cut it wet it will produce enough heat to weld it self back together. After cutting sand with 400 grit wet or dry sandpaper.-
Ron
