I have just finished trouble shooting the daylights out of my other bike and I need to know where the ignition pulse generator is? and if it is the same thing as the pick up coil, if so where is that?
Thank you
Under the left side cover w/stator, I believe it is part of the stator assy, and you need to buy it all together. Part of #8
192 ohms resistance then I tested mine with 2-red leds wired opposite in series with a 330 ohm resistor. Leds lit up when cranking the engine over.
Usually the two wires at the right side of the ICM harness break(wires break inside of the insulation). I do not believe any IPG have gone bad.
http://www.vtxoa.com/forums/album.php?albumid=315&attachmentid=61867
http://www.vtxoa.com/forums/album.php?albumid=315&attachmentid=61866
http://www.vtxoa.com/forums/album.php?albumid=315&attachmentid=56825
http://www.vtxoa.com/forums/album.php?albumid=315&attachmentid=56944
Discussion Starter #4
/QUOTE]
I would believe that but i have already fixed those wires. and checked continuity on them. Its not them, and i still have no power to the coils.:dontknow:
/QUOTE]
Do you have a resistance measurement to the IPG? Is it 192 ohms plus/minus 10%?
IF yes, then connect some diodes and a resistor as shown.
The IGN coils get +12v from the Engine Stop switch on the Black/White wire.
The ICM outputs a "ground" to engerize/fire the coils.
You can check for pulses with the leds also.
The Yellow/Blue and Blue/Yellow wires should have +12v on them all the time except when the ICM outputs a ground.
Make sure the neutral switch ground is getting to the ICM, if not no output to coils.
