I have 2002 VTX1800C and no voltage to the fuel pump...the shop manual says check the sub fuse...but where is it? None of the fuses in the fuse box under the right side cover seem to be it. The 30 amp main fuse is OK as my starter and lights work fine. The fuel cut-off relay is also fine. :?:
It is the D fuse in the 6 fuse pack. Red/black in white/black out.
Same fuse as the ignition circuit.
The key switch must be on.
The kill switch must be on.
The lean angle sensor must not be tripped.
The fuel pump relay must be okay.
Very complicated routing.
Fuel pump fuse
Thanks, the problem was one of the 30 amp blown (I know where to find them now)...now I can get back to the rear cylinder not firing! That's another thread.
