I have a 2002 1800C. I was curious as to what it would take to put a wider read tire on, say some where in the 200-220 range. I am new to the VTX cycle, but have seen a few wide rears on the net. Any info would be greatly appriciated. Cost, links to parts, etc... Thank you in advance :twisted:
Welcome to the board!
Without doing any modifications to the swingarm/driveshaft a 200 tire will go on the stock rim. Anything above 200 will require something to be cut&welded. Handler has a 210 kit that takes a stock wheel and makes it wider&bigger diameter to accept a 210 tire. http://www.gatewayxtreme.com/
After that now you're talking swingarm/driveshaft modification, fenders and seats. Some of those kits can be seen here on this sites sponsor HondaDirectLine or HDL(red banner at the top of the page)
http://www.hondadirectlineusa.com/vtx/b ... =699502713
8)
Discussion Starter #7
Baffeled at the info
Like I said i am new to the VTX world, and WOW!!! Seems you can pretty much walk down to the local 7-11 and get parts for these things. I haven't had much trouble finding accents, and with a group like you guys, custom parts seem pretty easy to come by as well.
I couldn't be more happy to be a VTX owner. You guys are awsome. Thanks for all the responses. Looks like I may have to empty out the rainy day stash from the sock drawr to get this done. Awsome. Simply awsome
