I know I'm new to this forum but someone highly recommends it and told me to check it out. My ride is an 03 VTX1800C. So far the widest bolt-on rear tire kit I found was a 250mm kit. I'm told you guys might know where to get a wider kit than 250. Maybe 280 or 300 perhaps...Thanx.
Welcome to the board!
I guess you don't mind going straight. 8)
True...I hear that turning with a wide tire is a pain...I'm sitting on a 200 now and turning isn't bad though.
