Will the Dunlop 250 fit on the VTX or is it only the Avon?
368 Views 2 Replies 2 Participants Last post by  dezzy7
Thinking about putting a unlop 250 on the bike and was wondering if anyone knew whether it would fit ok on the widened swingarm.
1 - 3 of 3 Posts
Depends on the swingarm. It will not fit on the standard swingarm as the tire mounted is closer to a 260. I used the wider BCC swingarm from HDL. Mine is with the soft tail setup, I assume that does not make a difference though.
The wider swingarm will also require you to make up some custom spacers depending on what rear wheel and if or without the Super Hub.
1 - 3 of 3 Posts
