Hi all,
Current situation
Fully charged battery; Engine stop switch in Run position; Tranny in Neutral; turn ignition on; neutral indicator, temperature dummy light, oil pressure light, running lights (front light bar) all turn on; headlight does not turn on, starter does not activate when I press the starter switch.
Background
I had been experiencing symptoms of lean mixture for a short while, and finally got around to cleaning the jets in my carb. I put it all back together and got it running, pulling it out of the garage and up the driveway. I needed to go get my helmet to take it for a test ride and turned off the bike. When I returned to the bike minutes later, it would not start (see Current Situation above).
I had been experiencing issues with my starter switch being "finicky" (had to depress it just right to get it the bike to start), but never had issues with the headlight not working. I had cleaned the contacts on the switch once before.
The only thing that was different from the hundreds of times I had started and shut the bike off before was, this time, I opted to stop the engine by turning the ignition switch off instead of using the engine stop switch first.
What I have tried
Knowing that there are two paths for switch settings to start the bike (Stop Switch in Run and either tranny in neutral OR kick stand up and Clutch disengaged), I tried all combinations of stop switch, neutral, kick stand switch, and clutch switch. Made no difference, so out come the tools.
Switch tests
- Neutral switch as continuity to ground when in neutral, no continuity otherwise (makes sense, seeing that the neutral indicator on the speedo works)
- Kickstand switch has continuity to ground when kickstand is "up" and no continuity when "down"
- Clutch switch has continuity when clutch is disengaged (i.e. when I am squeezing the clutch handle), no continuity otherwise
- Diode (flux capacitor? :lol
has continuity in one direction only (negative lead on center pin, positive lead on each outer pin)
- Ignition switch has continuity between all posts when switch is "on", no continuity between posts when switch is "off"
- Jumping the two primary connectors on the starter relay causes the starter to turn the engine
Fuses
- The main 30 amp fuse and all 10/5 amp fuses in the fuse block are all good (pulled each one out and checked continuity/resistance)
Voltage
I'll skip the "where I have voltage" conversation as some of it is obvious based on speedo lights working...
- No voltage on Y/R wire at starter relay switch when starter switch is depressed
- Obviously no voltage at the headlight (seeing that it doesn't turn on)
My thoughts
- Bad Engine stop switch / Starter switch, since the electrical path for both the headlight and starter go through the starter switch, and that is goverened by the engine stop switch.
Thoughts?
I pulled the housing for the engine stop switch and starter switch apart, but cannot figure out how to disengage the throttle cables in order to get the stop switch out of the housing.
I definitely have voltage drop across the poles of the starter switch. I am going to get that cleaned up and lubed today.
If this engine stop switch / starter switch isn't the issue, I am thinking I need to start tearing into the wiring harness for shorts. I hate to do that since the bike was running fine until I turned it off with the ignition switch instead of stopping the engine with the engine stop switch first.
Any thoughts are welcome / appreciated!
Current situation
Background
What I have tried
Switch tests
Fuses
Voltage
My thoughts
Thoughts?
