1 - 3 of 3 Posts
For those using these units, where do you have your antenna placed.
I've only had mine on the bike for a couple days, but can't find a place that the signal doesn't cut out.
Thanks for your input,
I bent a piece of metal at about a 45 degree angle. Bolted it to the top plate bolt. Magnet mounted the Sirius antenna to it. Ran the wire under the taillite rubber, then up and under the seat. Works well. Not as well as on a car roof, but not bad. Tree cover tends to let ya lose signal, being so close to the ground.
I've had mine attached to the handlebars right next to the brake reservoir. That has been the best reception I have gotten so far. From what you are saying, we've got about the same reception.
Thanks for your help,
Blessings
1 - 3 of 3 Posts
