Has anyone mounted the xtreme revolution fairing on a 1300S? Did you have to remove your upper fork covers or will the Memphis Shade mounting brackets work?
Photos of the mounting brackets would be appreciated.
Call um tommorrow.
I had already emailed them about this and they claim the Memphis mounting brackets on the R/S model is wider than the C. Not sure if this is true as I stopped at the local dealer and looked at the R/S and C's and the C's seem to have a wider gap between the forks.
Also read their instructions on the web and the mounts for the C require drilling of the lower tree. My Memphis mounts are already drilled into the lower tree.
Not sure if I want to take the fork covers off and change the looks of the forks.
