I finally just got around to installing the Hick A/F Screw on my bike. What a pita to get the old one out. Thank goodness I did not lose the washer or o-ring!
Here is my question. I have the stock air box and bub jug huggers on the bike. I really have no idea where the needle was set prior to taking it out (It was hard enough getting it out, I couldn't turn it in to see where it was set!). The stock needle seemed to turn out fairly hard yet when I put the Hick needle in seat it and turn it out 2 1/2 turns it seems really loose. Does 2 1/2 turns sound about right for a starting point with my set up? Will the needle stay in place once I have everything put back together? It seems at 2 1/2 turns it is about to fall out of the carb.
Mine is not tight but it's tight enough to not move around you should be OK as long as it's not wiggling aroung in there. I would start at 2-1/2 turns and then go from there. Seems to work for most on here.
Hey Question here....Is it not all the way in then 2 1/2 out ?? Just thought I would ask.
:oops:
I checked 2 or 3 times to make sure I had it seated all the way, but at the same time being careful not to turn it in too tight. I have it all put back together now just trying to find a way to adjust the screw while the bike is running so I can fine tune it.
I still use the stock A/F screw (just slotted it with a dremel). At first, it was a pain to get out so I could slot it, but then it moved very easily, almost too easily. It seats eventually (with the stock anyhow). I make minor adjustments here and there with a long screwdriver.
Hey, the simple thing to do is to just adjust the A/F even out to 2.5 turns. But if you really fine tune the carb, you'll end up changing the jets before going far over 2 turns. It just works better that way. Usually you're compensating for something if you just tune with the A/F screw. However, since you still have your stock airbox on, I think you should be able to just make minor changes with the A/F screw.
Stock is about 1.75 turns, I think?? You shouldn't need much more than that for new pipes and stock airbox.
Sorry for my long article in response.
Thanks for all the info. I didn't get a chance to take it for a ride and check the plugs but it definitely seems to be idling much better. I could never start it without the choke and now it fires right up. Also before opening it up a little if I revved the throttle and let off the bike would sometimes stall or at least the revs would come way down and then creep back up. Now it seems fine when I rev it. I will leave it at 2 1/2 for a while and see how it runs.
Thanks cybrhick for another great product! I told a local bike shop about this screw. They have had some problems jetting bikes with Hyperchargers. I know they purchased at least one. Hopefully they will be buying some more.
Todd
:oops:
Don't think I am wrong on this but the way I understand it is that you turn it until it seats (starts to get tight) THEN you back it out 2 1/2 turns. At least this is what I did and my bike ran fine but just turned it back in 1/8th to fine tune even more. I wouldn't feel good about over tightening it all the way in, if you do you might be in for a real surprise. :?
Isn't there suposed to also be a spring in there?
