Can't build up front brake pressure after forgetting to top off MC when flushing flui
1.4K views 9 replies 8 participants last post by  wayne
#1 ·
I can't seem to build up any pressure. I don't have a vaccum so I am relying on the old fashioned hand pump method. Any suggestions or recommendations to get pressure again so I can complete the flushing process?
#2 ·
Try pumping the brake lever very slow with the top of master cyl off & caliper valve shut. Check for bubbles at master cyl.
#4 ·
I recently had to work on the brakes on the GTO and I got a set of Speed Bleeders by Russell Performance. Not the best things since sliced bread, but close. Made it real easy to thoroughly flush all the brake lines out.
#6 ·
I went to HF and bought a Vacuum pump for bleeding the brakes and clutch. It sure made the job easy on the clutch. Next I'll be doing the brakes.
#7 ·
I think I'm going backwards. I used a vacuum bleeder, one of those hand pump gadgets, last time I changed fluids and didn't really like the way it preformed. Sometimes it would pull the fluid nice and smooth and sometimes not. I felt that maybe it was bleeding too fast and could have caused air pockets. I got everything done with no problems I just wasn'st comfortable with the tool.So this time around I think I'm just gonna hand pump everything the old fashioned way and see if I get a better result.
#8 ·
Yes this is the only thing you really need:D
