Painting over plastic chrome???
13K views 7 replies 6 participants last post by  Fyrfyghtr
#1 ·
What is a good practice for painting over the plastic chrome ?? I would like to paint my headlight and turn signals . Any help both do's and don't will be appreciated. thanks.
#3 ·
You can just scuff the chrome with some 600 sandpaper and water and spray some self etching primer to give the paint a good surface to bond to. Wet sand, clean, paint, wet sand, clean, clear coat. I didn't bother to final wet sand and buff my headlight, grill or neck covers and they look good.
#6 ·
What color are you painting it? and Do you have access to paint gun?
If the headlight is all you are painting, scotch bright and clean the headlight, prime and sand, paint, clear, wet sand to smooth.
If you are using a rattle can, I'd recommend DupliColor laquer black. That matches the black frame real well. It also covers well.
#8 ·
1. Scuff it good with 600 grit and clean it.
2. Apply a good adhesion promoter. Preferably the same brand as the paint you are using.
3. Apply 2 to 3 coats of self etching primer. Again the same brand.
4. Wet sand with 600 grit to smooth out and clean.
5. Apply color in several very light coats.
6. Apply at least 5 coats of clear. Same brand
At this point it will look ok but could be better.
7. Wet sand lightly with 1500 grit then again with 2000 grit and clean.
8. 2 choices here:
1. Apply a light coat of clear .
2. Polish with rubbing compound and again with polishing compound until you get a mirrorlike finish.
