This is with a fairing. Al bikes are different as well as fairings.
Mine is a hoppe the other was a woody. The woody took only one attempt to get it right. The hoppe took 3.
The forks are the first thing that has to ve checked. Leveling them is easy. The top bridge (where the forks goes through) must belevel. That will make it much easier over all.
The bike has to be completely vertical not off center. I use a home made condor and use tie downs lightly to keep the bike level and vertical.
The top of the forks must be exactly the same on both sides. I use calipers. You have to make sure all fasteners are tight. Once this is done.
I check the level of the fairing, first at the windshield mounting screws top. I want it perfect, not a half bubble off it is centered. If it is off, loosen the mounts, Hoppe and woddy fairings use worm drive clamps so it is rather straight forward.
Once I get that leveled I can then check the alignment of the front part of the fairing for fitment and being level.
In fact this is what caught my attention when I was installing the front. I noticed the back and front of the fairing was not leveled together. This is probably the time consuming part. After starting the screws to hold the front and rear together I had to really work to get the front to match to get them level and vertical together. The windscreen pays a big part in the leveling and wobble. I had to redrill one hole in the windscreen on the left side to get it level. I had to use angles (made from wood on my fancy miter saw LOL) to get the vertical so I could check the level. Then tighten all fasteners.
Went for a ride,felt a lot more stable. After a week of check all fasteners I took it for a good ride. Tested it at 100mph. No wobble, felt solid. Before around 70 mph or a large truck would cause a wobble, and it would increase with speed.
I made a post asking for help more than once, this was around 05-06 not real sure. Hoppe was about the only thing available for the vtx at that time.
I can do it now in less than a hour.
I have add fairings that were so close from the beginning It took only one try to get it right. It was a woody fairing. By the design of the woody It just seems to fit like it should.
Hope this helps someone. It took me weeks to figure this out but it did make a large difference on my X
